Salta al contenuto principale
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
455 Domande Visualizza tutte
SD Card Door Won't Stay Shut
The little flip up door that holds the SD card in place won’t hold the SD card in place.  Gorilla tape only works so long and not very well.  Is there a fix for that little annoyance you can suggest?  The device works perfectly fine otherwise.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Hello Gregory,
I would suggest maybe duct tape and put a lot of it. That should help keep the door shut. I cannot find a way to replace the door but if you want, I am not saying to do it. Pull out the flap and put duct tape over the place where the door used to be. If that does not keep the SD Card door in then I am not sure
Happy Fixing!
-Javen
@tacofixes
Punteggio 0
1 Commento:
I was hoping to not have to just add more tape. thanks.
da
Aggiungi la tua risposta
Gregory Redick sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 125
