Salta al contenuto principale
Lanciato il 21 settembre 2018. Modelli A2097, A2098. Disponibile come GSM o CDMA / eSIM o nanoSIM / 64, 256 o 512 GB /Argento, Oro o Grigio Siderale. (Si legge "iPhone 10 S").
Camera works but doesn't work
I recently dropped my iPhone and the back cracked forming a little rectangle around my back camera unit. My back-facing camera doesn’t work when using the camera app. However, when I use the camera via the Instagram app it works but it is zoomed in.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
There are two camera sensors in the rear camera assembly. Do into the camera app and switch between modes while holding your finger over one or the other then try the same in instagram. I’m wondering if instagram uses a different sensor. If you confirm the camera is damaged then you can get it replaced however you may lose FaceID if you or a third party replaces it as demonstrated in this video: https://www.youtube.com/watch?v=Apny-yVr...
Mind you this is a shady business practice by apple that we’re trying to fight against called Right to Repair.
Punteggio 0
Aggiungi la tua risposta
Rithraj Bondili sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 55
