Several isues: first only charging slowly when turned off, than..
- I did a screen replacement. - everything worked fine for days.
Than one day the phone couldn’t charge when turned on. It was very slowly charging only when turned off.
- I also noticed that sensor for light dont work when i was in a call the screen didnt turn black.
- Later i shut it down for charging. It never turned on again. It is stuck in reboot with apple logo. Reset dosen’t help.
- I have removed the screen, to check if everything is put together probably and i have found a CUT LINE which was connected to the frame. My frame is broken so it snaped the line.
- The question is: What is this line used for? in which assembly, could this be my problem? Is it repairable? How?
Questa è una buona domanda?
Punteggio
0
I think I don't know the solution, but I will try to help you as best I can.
I think your battery is the issue. Do you remember the battery health from before it stopped working? Have you used it for a long time?
Maybe you can stop the boot loop by resetting with itunes, but I think that won't fix your charging issue.
I have no idea what the cut line you're writing about does, but if your display works fine, I don't think it will be an issue.
I hope someone else will be able to help you further!
da Elias
I think the battery was on 78% health it was also written it needs a service... But it lasted me for a whole day basicly,
with average usage (couple h), so i dont know if this is an issue...
da jakob
It's still not bad, but it could be the issue. Have you tried restoring with itunes? Only worth it if you have a good back up, because it wil wipe your phone completely.
da Elias
