How do I reattatch a joycon rail
so i broke off my right joycon rail and have no modding experiance
Questa è una buona domanda?
Depends how it’s broken. Did you drop it? Or pull it? If the rail is still intact, you have to carefully open the Joycon, put it back and close it. For that you’ll need absolutely a TriWing (Y head) screwdriver.
If the rail is broken, you’ll need a new one.
Same thing if it’s the rail on the Switch’s side.
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 150
Depending on how you broke it you might be able to but it back on. Is it possible you can attach a photo of the joycon?
da Bri
same problem here. are the two flat cables from the rail intact like mine are?
da Hamm Khan
