Salta al contenuto principale
Processore dual core Intel Core i5 da 2,5 GHz (3,1 GHz con Turbo Boost) con 3 MB di cache L3.
265 Domande Visualizza tutte
MacBook won't charge after speaker replacement
Hi I used your guide to replace the speaker but now it won't turn on
The first run after reconnecting everything the speakers worked perfectly I had to reset date and time but it didn't recognize the battery it appeared with an x on the display
So I reopened I it to check if every thing was plugged in correctly
It was but when I connected the charger the light(green or orange) on the charger wouldn't lit and now I can't get the computer to start ,to turn on
Any advice????
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Since you’ve made sure everything was connected properly, I’d start by running an SMC reset. If the issue persists double check to be sure the battery is fully seated in its connector. All the pins need to be making full contact in order for the battery to be recognized.
Punteggio 0
Aggiungi la tua risposta
yojeved sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 36
