How to disable/trick/bypass the LCD temperature sensor..?
I have disconnected internal 5k display and have connected that to a circuit board allowing for external inputs (I can now use the 5k screen as external monitor with my new laptop)
I would still like to be able to use iMac as a computer - it will boot with external screen (even its own original screen connected “externally”) but the fan spins full speed and the CPU throttles… I assume this is because there was a temperature sensor on the LCD panel which is now not connected to iMac meaning iMac thinks its overheating…
Is there anyway to make the iMac ignore that sensor? slowing the fan will presumably not stop the CPU throttling… the sensor was connected through the iDP cable so there are a lot of very small pins and don’t fancy trying to short the sensor.
Questa è una buona domanda?
1 Commento
Apple uses a newer interface standard striking from LVDS to iDP.
da Dan
