Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
The Nintendo 3DS XL 2015, marketed as the New Nintendo 3DS XL, was released October 11, 2014 in Japan and February 13, 2015 in North America.
270 Domande Visualizza tutte
I droped my 3ds XL in the sink while the water was draning
hey so i droped my 3ds XL in the sink while the water was draning and i took it out of course but when i plug it in it works but it wont charge it only works when i have it on the charger what can i do to fix it?
Questa è una buona domanda?
Punteggio 0
Commenti:
oh woops i thoght this was the comints my bad
da
wait is it im confuzzled
da
oh um so can like bestbuy or gamestop fix my ds or will i just ave to get a new one ?
da
sorry if i seem dum im new to this
da
Aggiungi un commento
1 Risposta
Hi
The water causes corrosion and provides circuit paths for the electricity which were not in the console’s operating design and could damage the components. The corrosion process starts immediately and is ongoing until it is completely cleaned away
First do not try to charge or to turn on your game console and then remove the battery as soon as possible from the device to minimize any further damage.
Then you need to dis-assemble the rest of the device and clean all the affected parts using Isopropyl Alcohol 99%+ (available at electronics parts stores) to remove all traces of corrosion and water. If possible do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain additives and is not as effective. If you do have to use it, check the label to verify the amount of IPA. The higher the percentage of IPA the better.
Here is a link that describes the process. Electronics Water Damage
As always with electronics, especially surface mounted pcb be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board. Remove the shields that may be covering some components as the water may have got in under there and corrosion is occurring there also. The ends of any flex cables and their connectors need to be cleaned as well.
Hopefully after you have done all this the console might possibly work correctly again.
Here are the ifixit New 3DS XL Repair guides that may help.
If this process seems too daunting, take your game console to a reputable, professional electronics repair service, experienced in liquid damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Punteggio 0
Aggiungi la tua risposta
Lincoln York sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 17
