Salta al contenuto principale
A film and slide scanner from Nikon identifiable by the model number LS-40 ED.
5 Domande Visualizza tutte
Anyone know how to open this up for cleaning?
I have a Coolscan IV slide/negative scanner and would like to clean it. There is gobs of dust on the element. Can't really just get in there with an air can.
There are screws holding the steel shrouding on the back, but I cannot seem to get the plastic front plate off. Not sure if it should pop off, or if there are other connectors.
I would appreciate help here.
Many thanks!
Questa è una buona domanda?
Punteggio 0
1 Commento
If you check on the link I sent you, it says "To get the front faceplate off, use a flat screwdriver to gently pry the tab away from the chassis"
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
jmmx, check on here it should show you how to do it....Good Luck
Punteggio 2
2 Commenti:
This is great. I guess I will give it a try. I received a quote of $40-90. I am sure it would wind up closer to the high end.
Many thanks!
da
Wow that seems steep. Looks like you could do most of it by yourself. Just take your time and keep it clean ;-) Save some money....
da
Aggiungi la tua risposta
jmmx sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 1,940
