Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
3 Commenti:
How so?? You'll need to give us a bit more here. Does it not startup? What does the MagSafe charger LED telling you? Is it Amber or Green. Did you have a spill or bang/drop your system? Given its age have you had someone replace the battery?
da DanJ
i dint change the battery , do u the battery issue ? thxc buddy ,
da ali92
Can you answer the other points of what I asked
>> Does it not startup? Do you hear the fan spin up?
>> What does the MagSafe charger LED telling you? Is it Amber or Green?
Its a matter of following a diagnostic process. A then B then C and onward...
If you want to just jump to Z thats fine but it won't necessarily get you to the to the best answer!
da DanJ
