Salta al contenuto principale
Annunciato il 16 ottobre 2014, identificabile dal numero di modello A1347 e EMC 2840.
186 Domande Visualizza tutte
Unable to format new hard drive
Apple Mac mini "Core i7" 3.0 (Late 2014) Late 2014 - BTO/CTO - Macmini7,1 - A1347 -  2840
This one came in with a failing 1TB 2.5” hard drive. It also is set up as a fusion drive with a 128GB SSD blade. 16GB RAM.
I replaced the 1TB drive with a Crucial 1TB 500MMX SSD.
Had to boot the machine with the old 1TB standard drive attached via USB to SATA adapter. I am unable to format the new internal 1TB SSD drive. Tried an APFS format with Disk Utilities.
It is running Mojave. Do I need to break the fusion drive first?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
@mayer - You’ll need to run Disk Utility deleting all of the drives partitions (both the PCIe & SATA). Then reboot and run the internet recovery or use a prepped up USB OS installer. Just run the installer let it setup the drives.
Punteggio 0
Aggiungi la tua risposta
mayer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 23
