Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
4 Commenti:
ok that could be due to a bad power supply or a bruned fuse (there is a fuse built into the wii i noticed) id try useing a multimeter and use the dc power mode and see if theres anything (im also not sure the voltage)
da keith s.b
Dl you have a multimeter?
da Andrew S
how bout we start easy dose the red light trun on? on the power button
da keith s.b
My doesn't charge neither does it turn on, so if you get the solution please tell me
da Encrypted
