How to fix go pro hardware problem..it didn't power ON
it did not functon, i tried to use other battery other charger..
then i tried also to charger directly without batter then power ON, stil not working..
Questa è una buona domanda?
Punteggio
0
SuperR Pusok what model GoPro is this? You repalced the battery? Checked the charger to make sure it works? Cleaned the chraging port with some isopropyl alcohol? Checked for bend/broken pins on the charger? This could be a bad charger, bad charging port, corrosion on the inside of your GoPro etc. So we need more information to at least getting started
da oldturkey03
