Flashlight and magnifier app don’t work.
I replaced my rear facing camera, which solved the blurring and focusing problems, but now my Flashlight, Magnifier and Portrait mode do not work. Thank you!!
Questa è una buona domanda?
The flashlight will typically disable itself if the phone detects a fault, are both cameras definitley working?
I’m not completely sure. The camera works better in my IPhone 7 Plus,but Portrait does not work, nor does 1x. I can only take photos on 2x. I appreciate your thoughts, as I don’t know much about this subject. Is it possible that the replacement camera I received was defective or is this a different issue all together?
1x - does not work
Magnifier- does not work
Portrait- does not work
Flashlight does not work
yeah, if the 1x isn't working that will cause the others to stop as:
Magnifier uses both cameras
Portrait uses both cameras
Flashlight will disable itself if it detects a fault
New camera should work otherwise you may have a logic board issue
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 115
