excessive rocking and clanking during spin cycle
top loading Kenmore 90 series washing machine tub rocks and bangs during the spin cycle but when I hold or put pressure on the outer edge of the tube it the clanking stops but the tub still vibrates. I first made sure the load is balanced and the washer is level with the same effect. Next, I tried the spin cycle with an empty tub. It spins ok till at full speed and then the rocking and banging starts. While watching it I observed that the tub seems to lean back and bang against the back of the frame so when I put pressure on the front of the tub the banging stops. It still gives a strong vibration workout. Next, when stopped and I push down on the agitator there is no bounce but if I rock the tub it returns.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi,
What is the model number of the washer?
It seems as though there may be a problem with the suspension rods.
da
Aggiungi un commento
