bricked MacBook after upgrade to Big Sur OS
Bricked macbook retina I7 2017 after upgrade to Big Sur OS. Which part do I replace? Is this fixable?
Questa è una buona domanda?
You’ll need to speak with Apple to log the issue and for them to fix your system.
Sadly, there isn’t any part to fix this that you can replace here.
i was able to revive mine (a different one - mid 2014 mbp with retina) by disconnecting the io board with hdmi, sd card slot, usb and wifi. apparently the reason is a conflict between firmware (?) and that card (possible cause in my view is inability to initialize all the bootable devices - sd card and usb are among those). ill try to downgrade firmware - should get that board functioning again…
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 168
