Salta al contenuto principale
Lanciato il 26 ottobre 2018. Modelli A1984, A2105, A2106, A2108. Disponibile in versioni GSM o CDMA / eSIM, nano-SIM o dual-SIM / 64, 128 o 256 GB / Bianco, Nero, Blu, Giallo, Corallo o Rosso.
468 Domande Visualizza tutte
Hi, I had your new battery installed an it won't charge past 2%.
I had your new battery installed, won't charge past 2% tried different cables n plugs I checked the port for dust/debris. Still won't charge. I tried leaving it charge over night an same. Any info. Thanks
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
If they’re anything like the 8 series, I don’t necessarily thing it’s an issue with the battery. A lot of people, mostly DIY-ers and beginners, will knock off a component near the battery connector that is part of the battery gas gauge circuit, which is pretty self explanatory.
I would at least try to confirm whether or not I’m right on this by using the old battery, if it’s not severely bent or damaged. If it charges normally, then it’s most likely the replacement battery or the connector wasn’t seated. If the issue still persists with the old battery, you might have knocked off battery gas gauge or something related. If that is the case, you can get it repaired by someone who is skilled in micro soldering. This is not a repair you should DIY as you can mess up your phone beyond repair real fast. I recommend iPad Rehab, STS Telecom, or Rossman Repair. All of them have youtube channels you can check out. https://www.youtube.com/watch?v=h3gD-JqD...
Punteggio 0
Aggiungi la tua risposta
Brant Eberhardt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 47
