Salta al contenuto principale
Why won't my MacBook boot up.
I have a 15 inch non unibody MacBook pro that won’t turn on. It originally turned on when I got it last year no problem. Then it started to take longer and before harder to turn it on. I recently took it out of storage to turn it on and can’t get anything out of it. Last time i had to do something with the ram when it was plugged in to turn it in. Is it the pram battery?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Yes its possible your pram battery failed, also make sure your ram you put in was compatible( 667mhz ddr2 pc 5300 or 667 MHz DDR2 SDRAM). Try a pram reset or smc to see if it comes back on.
Hope it works,
Punteggio 0
Aggiungi la tua risposta
Owen Hewitt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 46
