Salta al contenuto principale
Guide per la versione LTE dell'iPad Mini 3. Annunciato il 16 ottobre 2014, l'iPad Mini 3 è il successore dell'iPad Mini Retina (ora conosciuto come iPad mini 2).
Flat flex cable connecting top right cellular antenna to motherboard
I noticed when repairing the top right cellular antenna that the little flat flex cable that connects underneath to the motherboard is damaged. This little flat cable is something you can’t order anywhere except to buy a damaged overpriced Ipad mini 3 to pull that part off. My question is this…..Can I simply just use a small wifi or Bluetooth cable and connect it that way? It’s the same little round connector.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
hello Frank,
even more :-) You can cut off the damaged connector and solder directly to the board (socket of this connection). If this is your iPad, remember that it is permanently connected. Also remember that the cable has the appropriate resistance. If it is too big or too small, the antenna will not work effectively.
  • regards,
Punteggio 0
Aggiungi la tua risposta
frank sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 33
Tutti i Tempi: 402
