Salta al contenuto principale
There are many versions of these Saeco coffee machines. They are very similar in structure and many repairs are similar.
8 Domande Visualizza tutte
After switch on: priming star for few seconds then E05 error
Dear,
Circuit priming message loops at beginning, then straigth away E05 error and asking to restart the machine, I did few times without sucess.
I opened the machine, and I can`t see any leak.
Any recommendation please?
My  coffee machine is Royal gran crema
Questa è una buona domanda?
Punteggio 0
1 Commento
Hi . The problem with E05 is generated of many SAECO coffee machine , I had this problem and I fixed it . See the video below and I am sure it will helps you .
https://youtu.be/0YR-xtacx1U
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Error code 05 means that the flow meter does not give a signal. Now you have to search: is the flowmeter blocked or broken? Or the water cannot pass through, e.g. because the heater or the pump is calcified. In Saeco Royal Pumpe austauschen the flowmeter can be seen in step 6, picture 2. Open the flowmeter and clean it, it's easy.
Punteggio 0
Aggiungi la tua risposta
anass sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 46
Ultimi 30 Giorni: 169
Tutti i Tempi: 5,445
