The screen only turns black after having replaced it
When it worked, the screen had vertical lines going through it.
It turns on and sound comes through so it isn’t bricked.
I tried re-inserting the screen several times.
Questa è una buona domanda?
1 Commento
I have the same issue. Had vertical lines and a crack on the edge. Bought a replacement LCD screen, changed it out with no problems, put battery in and powered on to test it. The screen is lit and you can see light around the edges of the screen. You can tell when you adjust the screen brightness but it's just a blank screen. There is sound and you can hear it clicking when you scroll but that's all.
da Rob Farnum
