Salta al contenuto principale
Guide per la versione LTE dell'iPad Mini 3. Annunciato il 16 ottobre 2014, l'iPad Mini 3 è il successore dell'iPad Mini Retina (ora conosciuto come iPad mini 2).
Can I remove logicboard and put it into A1599 housing? (IPAD mini 3)
Hey guys,
I’ve got a scenario here.
If I take the logicboard of an Ipad Mini 3 (Model A1600; wifi + Cellular), would it work if put it into the housing the IPAD mini 3 (Model A1599; just wifi) ?
I just want check if this is doable.
Thanks
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
This isn’t something I have tried myself but I suspect it would. The iPad mini logic boards aren’t screwed into the housing like iPhones are so you don’t have to worry about proper placement of screw holes. The main difference between the two versions of logic board is that the WiFi only board has a large hole where the RF infrastructure would be. All of the other flexes are universal.
So if you already have the two boards, I would certainly give it a try.
Immagine Replace a logic board (motherboard) compatible with the 3rd Generation iPad mini Wi-Fi model. Fix processing issues like unexpected shutdowns, reboots or water damage.
Prodotto
iPad mini 3 (Wi-Fi) Logic Board
$69.99
Punteggio 3
Aggiungi la tua risposta
Ckalable upflow sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 23
Tutti i Tempi: 673
