Salta al contenuto principale
Popular clothes dryer series by Kenmore.
60 Domande Visualizza tutte
Can a blown Cutoff fuse keep my dryer from starting
Changed thermal fuse and fixed heater coil that was grounded. It blew the timer which I also fixed and have Continuity everywhere except the cutoff fuse. It still won’t start. Is this why are is it Control panel issues?
Update (09/29/2020)
Roper mod# red4640YQ1
Questa è una buona domanda?
Punteggio 0
4 Commenti
It’s an older Roper model
da
I’ll get a better description if you need when I get off this afternoon
da
Thank you I really appreciate it!!
da
Update: the fuse was changed and dryer is running.... but now it just starts before pressing the start switch!!! Any suggestions?
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
What exact model is this? We need to know that in order to try and look at the schematic and yes a bad cutoff can be the issue, but there may be more going on here.
Update (10/01/2020)
Ben Lewis, I can confirm that if the fuse is bad the dryer won't start or will run but not heat. So I would suggest to start with the fuse.
Punteggio 1
1 Commento:
I posted in the old comments didn’t know if you would see it but the fuse worked but now when I put it on a cycle it just starts up before pressing start switch
da
Aggiungi la tua risposta
Ben Lewis sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 99
