Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
3306 Domande Visualizza tutte
Advice to store screws for Display replacement
Hey,
can somebody who already has done a display replacement give me an advice where I can keep the screws. I am a little bit afraid of mixing up the screws.
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
this is ifixit's guide which is on the display repair guide.Sostituzione gruppo display iPhone 4
Punteggio 3
Commenti:
Thank you very much, I glue this sheet on a board and drill holes into it :), then I cant lose the screws...
da
Theres better layout charts out there, but this is the one i like to use. make sure to tape it down and turn off any fans :)
http://unitediphonerepair.com/?p=73&opti...
Punteggio 2
Commenti:
Good idea, thx :)
da
I use a screw tray like this one.
I cut up some paper and label each compartment as I remove the screws from the device I am working on.
Having a tray with a lid is a good idea as if you take a break from the repair you can snap the lid down knowing that if it is disturbed or knocked over the hardware will at least stay inside the tray.
Good luck.
Punteggio 0
Aggiungi la tua risposta
arnonym sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 727
