Salta al contenuto principale
Un piccolo aggiornamento del MacBook Air di fine 2019, con lo stesso numero di modello (A1932) e numero EMC (3184). Questo modello ha uno schermo True Tone e una batteria leggermente revisionata.
100 Domande Visualizza tutte
Spilt coffee on it, been three days, won’t turn on
I spilt the coffee, I dried the laptop immediately after as well as I could, found out you should put it in a v-like shape (did that over night) and that didn’t work. I really need my laptop right now, I’ve tried everything can someone PLEASE HELP ME
Questa è una buona domanda?
Punteggio 0
1 Commento:
PLEASE HELP I haven’t even told my mum and dad yet I just wanna get it done before I have to PLEASE
da
Aggiungi un commento
2 Risposte
Vedi il contenuto dell'immagine:
Punteggio 0
sorry but I have limited info for you if you have a multimeter if you see this fuse on it when you open it and test it if something goes though then the backlight fuse is fine then test all diodes (if you are a kid then they only let power go though one way so test with positive and negative on both sides) red is positive black is negative) the picture is this website to get one of them if you need one
Punteggio 0
2 Commenti:
aare you aloud to take it apart?
da
@Ayden Aldrich idk, I’d probably be too scared to since i might cause more damage, thanks for trying to help
da
Aggiungi la tua risposta
Saoirse sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 72
