Battery not charging or holding a charge.
this iphone will not hold a charge i can plug it up to the wall and it works perfectly but as soon as i unplug it goes off.
Questa è una buona domanda?
Definitely a battery problem! Change the battery, or better yet, see if it is covered by a warranty and let the company you bought it from replace the whole phone.
Just replaced battery from here last night, worked fine. Put it on charger last night, as I normally do and it was dead when I woke up. It has the battery picture on the screen, but says it is charging, but won't turn on at all. Did I mess something up or is it a battery problem once again?
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,951
2 Commenti
Is there water damage? the connector for the battery might be corroded and need to be reflowed.
da iRepairMan
New battery?? Just a guess...
da iRepairMan
