Salta al contenuto principale
Why won't my speaker turn on?
I have a shower speaker which will not turn on. Whenever I charge it It shows that it is charging but it never finishes. The Led light always remains red. When I do attempt to turn it on the device is unresponsive and the blue led light doesn’t show. It didn’t start this until recently. Could someone help?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
Hi there,
The power switch may be the issue, it could be the switch itself or cold solder joints on the power switch. If it has a sliding on/off switch the little arm on the switch could be broken meaning the part you slide has nothing to catch on to to move the physical switch to the on position.
Punteggio 1
2 Commenti:
Thanks for your reply but my device doesn't have a switch just buttons. I tried to put a picture but the resolution was low.
da
If you can I would open it up and have a look at the power button, if you have a multimeter you can check the continuity of the button.
da
I had the same problem. I had to lift u other middle part where the cover with all the symbols are on it. Once you do you will see the circuit board, look around the edges to see if there is corrosion if so take a cotton swab and vinegar, or water and baking soda, to remove the corrosion. Should work fine after.
Punteggio 0
Aggiungi la tua risposta
Jay Jackson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 34
Tutti i Tempi: 1,985
