Salta al contenuto principale
Modello inizio 2011, A1278 / processore i5 2,3 GHz o i7 2,7 GHz
779 Domande Visualizza tutte
Does not go to sleep when lid is closed
Hello,
After replacing the battery on this computer, the computer does not go to sleep when the lid is closed. Everything else works fine. Maybe it is a damaged hall effect sensor?. What would most likely have been damaged in the process of replacing the battery that would have caused this? How would I go about fixing it?
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi there,
Is the display setting set to always on?
Punteggio 0
1 Commento:
No. No software settings were changed after the battery was changed, including the display settings. It used to go to sleep before.
da
Aggiungi la tua risposta
Albert Einstein sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 46
