Salta al contenuto principale
Un piccolo aggiornamento del MacBook Air di fine 2019, con lo stesso numero di modello (A1932) e numero EMC (3184). Questo modello ha uno schermo True Tone e una batteria leggermente revisionata.
98 Domande Visualizza tutte
Water is trapped in Retina display, is this beyond repair?
Hey guys- my MacBook Air 2019 got rained on last night. Everything works except there appears to be a significant amount of water inside the screen. (I should mention the actual display works perfectly fine, I just pulled up an all white screen so you can see the water) Is this something I can fix or is this beyond repair and needs a replacement? Thank you!
Questa è una buona domanda?
Punteggio 0
2 Commenti
Hello! I've seen that in some cases on the internet the water evaporates on its own. I just have the same problem and was wondering if it evaporated for you too?
da
@jazzvega - I wish it was so simple😢
If it where pure water (think distilled like whatever you use for your cloths iron) the sure evaporation might work. But rain water as well as what comes from your tap is not pure! Far from it! This other stuff won’t evaporate, instead leaves a film and some of it is organic! Like molds and algae which will to the mess.
The last issue is a closed container has a much harder time for the liquid to evaporate and the temp is also a factor. So you will need to warm the system a bit to push things along.
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Wow that was some rain storm!
Well, to start with you likely have more wetness inside the main case area so I would disconnect the power cord if you still have it plugged in and you should disconnect the battery until you’ve had a chance to fully check out your system for wetness. I would make sure the rest of the system is good before you worry about the display Ask iFixit: I Spilled Liquid on My Laptop—Now What?
As far as the display its a goner ;-{
Here’s the guide to replace it Sostituzione schermo MacBook Air 13" Retina Display 2019 and here’s the needed part 13” MacBook Air Complete Display - Silver, Apple P/N 661-12587
Punteggio 1
Aggiungi la tua risposta
Noah Thomas sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 57
Tutti i Tempi: 1,273
