Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
1049 Domande Visualizza tutte
won’t turn on after screen replacement
After replacing the screen and home button, the phone will not turn on. Did I fry the logic board with static electricity or what? Any diagnostic procedures would be appreciated. I have parts from an iphone 5 if needed.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hello Killian,
Plug your phone into a PC, is it being recognized? If so, did you disconnect the battery first? If you didn't there's a chance one of the filters is gone. Take a strong flashlight and shine at the screen, does anything show up? It's usually the case of backlight not working. If you disconnected the battery first have a look around the screen connectors, you might've knocked off one of the microscopic components off. Next have a look around battery and charger ports for any pry damage.
It's also possible you didn't connect the battery / charge port properly.
Punteggio 0
Aggiungi la tua risposta
Killian Brown sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 100
