Salta al contenuto principale
Lanciato il 21 settembre 2018. Modelli A2097, A2098. Disponibile come GSM o CDMA / eSIM o nanoSIM / 64, 256 o 512 GB /Argento, Oro o Grigio Siderale. (Si legge "iPhone 10 S").
376 Domande Visualizza tutte
Dropped iPhone in water, Phone died, Won't charge
So I dropped my phone in a pool last night and it worked on my way home until it died. I tried charging it last night but got the water in lightning port thing so I just thought I’d let it sit and charge it in the morning. I tried charging it this morning and it shows the little battery dead icon and when I plug it in it changes to the one without the cord on it but it will never turn on. Also there is a green strip going down the screen when it shows the battery dead icon. It is there sometimes but goes away sometimes as well. I thought the IPhone XS was water resistant so I didn’t think it was that big of a deal. It was maybe not even a foot underwater. Can I fix this or should I go to a repair store somewhere?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
You can take it to a repair shop but it might not be worth it to fix. Once it gets wet corrosion will start immediately and it is worse if electricity is applied. You definitely shouldn't have changed it. The screen is definitely dead. Most shops won't work on water damaged phones except to retrieve data. Did you have a crack on the screen or back of the phone?
Punteggio 1
5 Commenti:
You can try putting it in a bag of rice for 24 hrs or so to draw out the moisture, however I think Allan may be correct.
da
Rice does nothing except get stuck in the charging port. The rice myth is just a myth it doesn't do anything.
da
Do NOT PUT IN A BAG OF RICE it does nothing for it except to get rice stuck in the charging port. If you were able to take it apart and dry it off from the inside there is a small possibility it will work but who knows for how long I wouldn't bother fixing it unless it had information you wanted off of it. Most repair shops won't even work on phones that have been wet except for data recovery.
da
@sithlord rice does nothing, why do people think rice dries out wet phones?
da
@strongbow I remember TheVerge having an article about it years ago. I seem to recall them dating the myth back to at least the 40s. This myth was all around when mobile phones came to life (way before smartphones). I had a “huge” Philips thing, back in the early 90s, and even back then people swore to the rice for moisture damaged devices.
da
use a wireless charger
Punteggio 0
Aggiungi la tua risposta
Filip Kates sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 42
Tutti i Tempi: 1,917
