Salta al contenuto principale
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 Domande Visualizza tutte
'Liquid' like Spots on screen?
Hello,
I decided to try and repair my own iPad and I think I failed. The screen has these bubble like things when I press on the screen. The screen hasn't been dropped and I purchased what I thought was a ‘premium’ grade screen + LCD replacement. My original screen had them too and Im not sure what they are or how to get rid of them. Also I couldn't figure out how to correctly reassemble the home button. It's either significantly lower than before or it gets stuck.
Thank you in advance for answering.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Is the frame bent in any way? I know you said you got a premium display, but where from? If the spot disappears when you lift the screen off, there may be something pushing against the LCD causing this pressure spot.
Punteggio 0
2 Commenti:
I bought it from mobilesentrix. From what I could tell it isn't bent at all. The pressure spot is more apparent when pressing the home button.
da
@cfphonerepair I order from Sentrix myself. there could be a possibility of a defective display but seeing as it was an issue before, there's gotta be something pushing up on the screen. I know this may sound silly, but did you install the new screen and not the old one by mistake? I've done that before a couple times XD
da
Aggiungi la tua risposta
Cindy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 159
