Salta al contenuto principale
Numero modello A1707. Rilasciato a giugno 2017, questo MacBook Pro adotta processori Kaby Lake fino a Intel Core i7 quad core da 2,8 GHz con Turbo boost fino a 3,8 GHz.
324 Domande Visualizza tutte
Fan runs over full speed after battery replacement
Hello. I’ve replaced a battery and now the left fan starts to run at 134%¹ just after turning on mpb. The right fan is starting at very low speed, then it overclocks, so I think it works fine. But there is no any sensible lags on working, cpu temp is fine, only real issue is a fan noise.
I’ve tried to reset SMC and NVRAM by several times, nothing has helped.
¹ By osx-cpu-temp tool:
  • CPU: 50.9°
  • GPU: 51.7°
  • Left fan: 5028 RPM (133%)
  • Right fan: 0 RMP (0%)
While by Macs Fan Control app:
  • Left side (min/current/max): 2160 / 7191 / 5927 on AUTO (custom setting IS NOT CHANGING the speed)
  • Right side (min/current/max): 2000 / 2000 / 5489 on AUTO, custom setting works fine
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Inspect the ribbon cable from the fan unit for damage as well as look at the ribbon cable connector and the matting connector on the logic board for damaged pins. also make sure you inserted the ribbon cable fully.
If you don’t see any damage then you’ll need to replace the fan assembly: MacBook Pro 15" Retina (Late 2016-2019) Left Fan
Immagine MacBook Pro 15" Retina (Late 2016-2019) Left Fan
Prodotto
$29.99
Punteggio 0
Aggiungi la tua risposta
Anton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,298
