Salta al contenuto principale
MacBook won't turn on, battery dead?
I found our old Macbook Pro in the cabinet, and tried turning it back on to see if it could still be salvaged. Upon pressing the power button, I get no sounds from the fans, so I presumed the battery was dead and needed charging (considering it hasn’t been used for almost 5 years). I plug it to its charger (and that to the wall outlet), and get a steady green on the MagSafe connector, and I also noticed the battery indicator on the side of the device blinks five times. I’m not entirely sure what this means, but I’m assuming the battery is dead.
Does anyone have any ideas on what I can do to check what’s broken before I go on and buy parts to replace for this? Thanks in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
The blinking checker LED’s is telling you the battery needs replacing MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Battery and here’s the guide Installazione della batteria nel MacBook Pro Unibody a 2,53 GHz da 15", versione metà 2009
Immagine MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Battery
Prodotto
$89.99
Punteggio 1
1 Commento:
Thanks for this! Sorry I couldn't check responses earlier, but I'll look into getting a replacement battery for my unit. Again, many thanks!
da
Aggiungi la tua risposta
SevenPx sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 42
