Sorry this is not FlexGate that was the backlight ribbon cable which is a different cable from the displays data cables.
Here the data cables are marked in purple (click to get full image)
The logic board they connect to has a few chips under the metal shields, this logic is called a T-CON board. It creates the needed LCD raster horizontal and vertical signals converting them from the logic board connection signals.
This board is part of the display assembly and its what has failed here.
Sadly the demand for used parts has stripped the market for used parts presently. All I can find is new parts here’s one source:
13” MacBook Pro Display Assembly - Space Grey, Apple P/N 661-07970
13” MacBook Pro Display - Silver, Apple P/N 661-07971
And lastly, here’s the guide: MacBook Pro 13" Touch Bar 2016
The 13" models cooling system better sized over the 15" model. Unlike the 15" had a second hot chip! We are seeing a lot of the 15" models encountering this failure as well as over & under scanning which creates black & grey bars at the top and bottom edges.
Here you likely overheated the system with dust build up or blocked the vents (using the system on a bed or rug floor) so the air flow was reduced.
Playing games or videos can push the thermal load.
Best to visit an Apple Store (free estimate) let them verify.
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
