Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Modello A2116 / 2019 / processori i3 quad-core 3.6 GHz, i5 6-core 3.0 GHz oppure i7 6-core 3.2 GHz. Rilasciato il 19 marzo 2019.
41 Domande Visualizza tutte
Upgradability of iMac 21.5 inch
I am planning to buy an iMac 21.5-inch Retina 4K but I would like to know how much upgradability there. I know that the RAM is upgradable up to 64GB. I am buying one with a 1TB Fusion Drive, but can I change this to an SSD after purchasing? Since Apple charges a lot for extra storage and RAM. Can I also upgrade the processor? It comes with a Core i5 but if it is possible I would like to upgrade to an i7 at minimum.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
YES!! you can pretty much upgrade everything except the display
Punteggio 0
Commenti:
@ranger1509 - Please expand your answer! What are the drive options and limits as well as which CPU's are workable.
da
@ranger1509 - That is not correct! Intel CPU's have micro code loaded in the systems ROM. This microcode is unique per the chips series as an example here Coffee Lake: Intel Core i3 (8100), Core i5 (8500), or Core i7 (8700).
The other variable is the TDP can't be more than 65 W. So as an example a i9-9900K (Coffee Lake) is 95 W which won't work properly in this system as the power supply and cooling would not be able to support it.
What are the logic board I/O's for storage devices?
da
Aggiungi la tua risposta
Abel Benoie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 143
