Salta al contenuto principale
A1708 / EMC 3164 — Lanciato a giugno 2017, questo MacBook Pro entry-level conserva i tradizionali tasti funzione (invece della Touch Bar OLED.
563 Domande Visualizza tutte
MacBook doesn't wake after closing lid unless I reset smc
Hello,
I’m having some troubles with my 2017 non-touchbar macbook pro. The macbook works operates fine but once I close the lid, I can’t wake the computer unless I reset the SMC holding CTRL-Option-Shift-Power. As long as I don’t close the lid, I can sleep from the power menu and wake it by pressing any button the keyboard. I’m thinking it’s a problem with the lid sensor. This obviously gets very annoying since I cannot close the lid without having to completely reset the smc and reboot every time. Could anyone help me out?
Questa è una buona domanda?
Punteggio 1
6 Commenti:
Bumping for answers :(
da
In my case, I've observed by using an external monitor that the internal display disappears in MacOS. I don't know if this can help you...
da
By the way, I have this problem in a Late 2016 MBP 15"
da
Hi James, Have you found the solution to this problem yet? I'm experiencing the same thing with same model year mbp.
da
I had the same problem. I turn off power nap and it works
da
Mostra 1 altro commento
Aggiungi un commento
4 Risposte
I remember watching a video posted by Louis Rossman on an issue like this. I believe it was a sensor used to detect when the lid is opened. It uses a magnet and when the sensor goes bad, it doesn’t wake up the display. Try connecting it to an external display and see what happens.
Punteggio 0
Having the exact same problem here with a MacBook Pro late 2016 with touchbar.
I think it has something to do with the serie of problems people experienced since the the 10.15.4 update (Kernel Panic on wake up). https://discussions.apple.com/thread/251...
I managed to work around the problem by disabling Power Nap in the Energy Saver control panel and then by turning off the sleep mode altogether, but yet I still need to reset SMC everytime I try to restart after the lid has been closed.
Very annoying.
Punteggio 0
Same problem here for A1708 Macbook pro. History: Macbook did not turn on at all and a repair shop diagnosed, that i needed the logic board to be replaced. I found it way too expansive. One year later I changed the logic board by myself. The spare part is a used but okish logic board. Now, the mac works and i could safe my data and make a factory reset. However if i close lid, the mac book turns off screen but does not go to sleep. If i turn it off and turn it on without closing lid, all is good. When i turn off and close lid I cannot turn on again. I always need to power on with smc reset.
Some guys said its a problem with battery cable, but i checked it and it does not make any sense. Maybe something with the display cable? Or lid sensor? But where is this sensor?
Punteggio 0
1 Commento:
Yeah I listened to the same guy, bought a new battery cable and didn't work...
da
Any update on this? I am facing the same issue.
Punteggio 0
Aggiungi la tua risposta
james kang sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 38
Tutti i Tempi: 2,264
