Salta al contenuto principale
A1418 | EMC 2889 | Late 2015 | 1.6 GHz dual-core Intel Core i5 or 2.8 GHz quad-core Intel Core i5. Released October 13, 2015.
iMac Right audio output has crackling noise when using headphone jack
Hi,
the right audio output has the crackling noise whenever I use the headphone jack for any external devices. Does it affect the computer if I don’t fix it? and what should I do in order to solve the problem?
Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
ccz827 sounds like a bad jack. What should I do in order to solve the problem? It is soldered to your logic board so unless you are planning to replace it by resoldering a new jack, I would suggest considering an external USB device to eliminate that. Does it affect the computer if I don’t fix it? No, it will not aadversely affect your device.
Punteggio 4
1 Commento:
Hey oldturkey03, I've almost always found that when audio things get "static...E" sound like that, it's almost always a bad grounding on either the jack or plug end. Usually the jack end since it gets most abuse and the ground wire gets loose. Cheers Bud, Stay Safe!
da
Aggiungi la tua risposta
ccz827 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 284
