Screen extremely dim, Replaced screen assembly and same problem?
Iphone screen (I Thought) failed on my original unit. The screen still is functional but was nearly impossible to see (almost like a backlight failed).
I decided to order a new screen assembly from this site to give it a shot. I have installed the new screen… After replacement I still have the exact same problem as the original screen.
Basically it is like the screen is at 1% brightness… Almost impossible to see. Any ideas? Thanks for the help!
Questa è una buona domanda?
4 Commenti
Any update on fix to this issue?
da chet
Chet,
Checkout my profile for the website address, the fix for 3Gs and Iphone 4 Backlight faults can be found there.
da ajwwoodward
i went to apple you need a new phone !@!!! not fixable
da tj rooney
@tj rooney,what did they tell you was broken? What have you tried to fix it? New LCD, 6R8coil, 109L IC, checked the traces on your logic board? You see, there are possibilities before saying that it is "not fixable"...
da oldturkey03
