Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1688/A1633. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 32, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
2573 Domande Visualizza tutte
Screen very dim after replacement
Guys maybe you can help me, after the screen replacement the brightness of the screen is very very low, almost impossible to see I have to put a light against the screen to see something, what can it be?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi Francesco,
It sounds like the backlight on the screen is not working. This may be due to a blown backlight circuit—which may happen if you tried to reconnect the display with the battery attached and powering the logic board.
You can try to carefully re-seat the display connectors (make sure to disconnect the battery first) to see if that will solve the issue.
Punteggio 0
Commenti:
Thanks, I think you are right, I probably didn't realised when I was connecting the display the battery was still connected. Unfortunately I tryied to re-seat the connectors but nothing changed. Sometimes seems the backlight is coming back, like flashing for one second.
da
Aggiungi la tua risposta
Francesco Bandinu sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 56
