Salta al contenuto principale
Lanciato il 25 settembre 2015. Modello A1687/A1634. Si ripara in modo simile alle generazioni precedenti, richiede cacciaviti e strumenti di apertura. Versioni GSM o CDMA /16, 64, 128 GB / Oro rosa, Oro, Argento, Grigio siderale.
985 Domande Visualizza tutte
Why is my screen black even when its turned on?
I dropped my phone from like 3ft off the ground, it fell on the back with a case on it. The phone still turns on but the screen is just back. I can use siri and i can still tap the screen but its just black.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
It sounds like it is your backlight. The backlight is just what produces the colors on your phone. Try reconnecting your screen to the phone. The screen may have been knocked loose when you dropped it. The backlight itself is located on the logic board so i don’t think it was damaged. Reconnecting you screen will probably fix it.
Punteggio 0
Aggiungi la tua risposta
morgan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 22
