Yep! A iPhone 8 screen works perfectly when installed in a iPhone SE 2020, and vice versa. Additionally, after a screen swap, you can follow the same procedure using a iCopy to transfer the serial number from the old screen to restore TrueTone functionality just like with the iPhone 8.
So, the only parts in the iPhone SE 2020 that are NOT compatible with the iPhone 8 are:
- the rear camera. It looks the same, and plugs in fine, but it just doesn’t work.
- the battery. The battery in the iPhone SE 2020 is the same form-factor at the iPhone 8, but the connector is the same as the battery used in the iPhone 11.
As soon as parts are available for the iPhone SE 2020, I’m tempted to buy a logic board, battery, and camera and install them in my old iPhone 8 to make a sort of “franken-phone”.
Anyways, hope that answered your question.
Votato
Annulla
Punteggio
12
1 Commento
comparing the two phones on Apple everything in the display is the same besides the iPhone 8 screen using 3D Touch and the new SE having haptic touch, also Apples screen repair price for the iPhone 8 (UK) is £152.44 and new SE £136.44 it’s a shame but suppose it’s a cost saving measure. If anything probably will work but not sure how the above would work if swapped around, Hope this helped
da daled460
