Salta al contenuto principale
A USB (Universal Serial Bus) cable is a common type of cable used to connect devices such as computers, smartphones, printers, cameras, and other electronics. It is designed to transfer data and power between devices, and is often used for charging devices as well.
15 Domande Visualizza tutte
Can I re-solder a lightning cable?
The cable is broken near the connector, can I re-solder it?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
It’s not something I would recommend!
If the cable is physically attached to the device can you open the device to get to the points the cable wires are connected too?
If you can I would just replace the full cable.
Punteggio 2
Aggiungi la tua risposta
Hutchoo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 743
