Correction! It was not iFixit! The company I had worked at did the testing of M.2 PCIe/AHCI SSD's and did a little with PCIe/NVMe SSD drives in 15" 2012 & 2014/15 retina MacBook Pro's.
The information was never published as it was for internal use on our usage for upgrading the systems we had as we needed more storage than what Apple was offering at the time and also wanted to find cheaper solutions as well.
It was not good! We tested over a dozen SSD's using at the time five different carriers. Some where better but the error rate was still too high!
Remember that was at that timeframe, the carriers have likely improved, I have not done any further testing as I just don't have the resources I did back then. I still don’t recommend them as the systems I work on are mostly high end users who need reliable solutions artists, sound engineers, photographer & videographers.
I either use real Apple Samsung or OWC SSD’s internally. Often times I guide my clients to get the system with the largest SSD they will likely need and as most of my clients use desktops I push Thunderbolt2 or 3 (USB-C) external drive solutions for their mass storage needs.
Here’s a better view of the M.2 interface
The mSATA is the Red path, AHCI & NVMe use Lime path via PCIe
Here’s a deeper reference on the different Apple SSD’s The Ultimate Guide to Apple’s Proprietary SSDs
Votato
Annulla
Punteggio
2
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
