Salta al contenuto principale
Seconda generazione di iPhone. Modello A1241/8 o 16 GB di memoria/plastica posteriore bianca o nera. La riparazione è più semplice rispetto al primo iPhone. Richiede l'uso di cacciaviti e strumenti di leva e distacco con ventose.
20 Domande Visualizza tutte
Why can't I turn the phone on?
I took the front off of the phone to place the 1 tab back into position as I was getting a white screen issue. After putting the phone back together I couldn't get it to turn back on. I didn't even fully take it apart, only lifted the screen long enough to put the tab back into place. Any suggestions?
Questa è una buona domanda?
Punteggio 12
Aggiungi un commento
6 Risposte
Risposta Più Utile
check that the lock-switch connector is on fully, as there may be no hardware failure, but somthing preventing you from turning it on.
Punteggio 2
3 Commenti:
Where is the lock-switch connector?
da
Where is the lock-switch connector located?
da
Om the right corner o.
da
i think my phone have hardware problem
Update
please show me phones diagram
Punteggio 2
1 Commento:
gayan, it would work so much better if you ask your ow Click on the link on the right side of this page. "Ask a question" and give as much detail as possible.
da
my samsung s4 is not working it fell the screen cracked and the mother board not working i cant switch it on
Punteggio 0
wen i turn un my phone it stop by the starting tone
Punteggio 0
why cant my phone turn on
Punteggio 0
My G3 Phone can not on
Punteggio 0
2 Commenti:
da
Please what shall I do?
da
Aggiungi la tua risposta
shannon sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,043
