Salta al contenuto principale
iPhone con schermo da 4" introdotto nel marzo 2016 con specifiche hardware simili a quelle dell'6s. Disponibile in Argento, Oro, Grigio siderale, Oro rosa con 16 o 64 GB. Modelli A1662 e A1723.
1049 Domande Visualizza tutte
Replacement Screen Won't Turn On . Bricked A Replacement Screen?
Hey guys!
So I’ll cut to the chase because I’m pretty stressed right now. I was doing a screen replacement on my SE and as I was reassembling I connected the 3 top connectors and the battery and did a screen test. The screen lit up and asked for my password but I noticed that the screen did not respond to my touch. Noticing that one the 3 top connectors had come undone (the bottom-most one), I tried to turn the phone off. However, since the screen did not respond to my touch, I couldn’t turn it off the normal way and foolishly just went at the problem by disconnecting the battery connector and then the 3 top connectors until the screen went dead. Second time round, the screen won’t turn on at all.
Plugging my phone into my PC, I find that the phone vibrates (3 times) and that iTunes asks if I’d like to install an update.
Please help. I’m not sure if I just bricked the replacement screen and need to buy a new one or that my phone is now destined for the recycling centre.
Thanks in advanced, stay safe and stay healthy
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
you may have fried it.
typically ill let a device completely die before even working on it.
that way if something like this happens i dont have to wait long for it to die and turn off that way.
my only advice would be to take it apart again and look to make sure all the connectors are still good. if so then you may have fried it :( the only other way to test it unfortunately is to buy ANOTHER replacement and see….
Punteggio 0
Aggiungi la tua risposta
TreeAndPlants sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 37
