Salta al contenuto principale
Can I replace the cracked display frame that mounts the LCD?
Looking to revive my old Macbook Pro 2009. It has been sitting in the basement because I have cracked the Metal Frame that mounts the LCD which is why I can’t close it. Everything else works fine except the wifi but that may be an issue with my battery since it already has a service warning. Any suggestions where I can find a replacement or what to search for (because I have been because welding it is not an option. Thank you!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
This is a well known issue. I have repaired several using a heavy buildup of epoxy. I also used cut paper clips as a sort of rebar imbedded in the epoxy.
Punteggio 1
2 Commenti:
I am planning to test something out because I have some small thin steel bars lying around might use it to reinforce the bracket but I might try to screw it in to be more secure. Are their any wires/ pcb /components underneath or inside the bracket that might get damaged if I drill 2 holes on it?
da
You can drill. If you look at it, this is a very thin spot in the frame and they all break in the same location. I also used a Dermel type of tool with a cutting disk and roughed up the surface to help creat a better physical lok of the epoxy.
da
Aggiungi la tua risposta
Ranzel Ong sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 31
