How to stop Thermal Throttling
I recently did a teardown top to bottom clean on my Macbook Pro, and accidentally ripped the trackpad cable, which contains a temperature sensor.
Due to that, the fans run at full blast and the CPU is throttled because it believes something is at 100C, however using an app such as MacFansControl I can confirm that that maximum temperature is 40C, so there is no need to throttle or run the fans at full speed.
Using Activity Monitor I found that Kernel_Task is using all of the available CPU, and causing lag. The lag causes the system to be completely unusable, and I would like to stop this from happening as I rely on this laptop to work from home.
Edit: I forgot to mention that I am running High Sierra, 10.13.6
Questa è una buona domanda?
3 Commenti
Crap that’s nasty the first time i did a teardown on an old laptop I totally ripped the cable socket on motherboard side
da technochicken
soory if that wasn't helpful! just going off on a rant
da technochicken
Oof that’s horrible. Me too
da Koston Morin
