WIFI not working after replacing lightening connector
I replaced the lightening connector assembly and everything seemed to go back together just fine, but after starting up the phone again, the wifi is not working. Specifically, the wifi cannot be enabled, the switch in settings is off, and cannot be turned on.
Questa è una buona domanda?
When replacing the lightning connector, did you remove the logic board or just lift it up?
da Jade Richards
If removed could have damaged the wifi antenna signal flex or even ripped the flex to it.
da Jade Richards
@Jade Richards I did completely remove the logic board and then re-installed. I guess my first step would be to re-open and inspect the wifi antenna component and its connections. I'll do that and post any updates!
da matt
