Salta al contenuto principale
Lanciato il 21 settembre 2018. Modelli A2097, A2098. Disponibile come GSM o CDMA / eSIM o nanoSIM / 64, 256 o 512 GB /Argento, Oro o Grigio Siderale. (Si legge "iPhone 10 S").
345 Domande Visualizza tutte
What is this thing and how do I fix it?
Hi,
This material between the front glass and stainless steel band on my iPhone XS has been damaged from a fall; a bit of it is kinda scraped off. I think JerryRigEverything called it a buffer or something in his durability video for the XS Max. I don’t know if it’s plastic, rubber or composite.
Attached image shows the material I’m talking about. It’s obviously not my phone; I don’t have a camera with me at the moment, sorry..
1) What is this material and what does it do? Is it rubber? Plastic? Composite?
2) How would I go about replacing it? Do I just get a new display? Does it come with a new display? iPhone XS Screen
Appreciate any help. Thanks :)
Immagine iPhone XS Screen
Prodotto
iPhone XS Screen
$109.99
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Risposta Più Utile
It’s called the bezel, It’s plastic cast around a metal frame, used to reinforce the screen and serves as structural attachment between the case and the screen. It is adhered to the glass with what looks like industrial strength adhesive and the adhesive loops the whole edge of the glass to make a water resistant seal.
Also it is the sealing interface between the screen assembly and the case. Removing the frame is extremely difficult and there seems no reliable way to reattach a new one to seal properly.
You may need to cut open the metal bezel, remove a few structural screw holes, then try to dissolve the adhesive and cut along the display, refer to below video.
https://www.youtube.com/watch?v=syC-HJLj...
Punteggio 3
5 Commenti:
It's not a bezel, it's a strip of rubber meant to protect from impacts.
da
@yootzmedia no it’s plastic cast over metal frame, it does provide some bumper space between the screen and case, now ever the core structural element is the metal frame, which holds the glass down
da
@tomchai @yootzmedia @jaderichards Is it plastic, or is it rubber? Rubber would have a lower melting point, right (correct me if I'm wrong) ? Thanks :)
da
Plastic. In my opinion, don't do this repair, you'll lose too much for just a cosmetic scuff.
da
Its a hard plastic in my opinion but is the frame of the whole screen tacked onto the inner metal frame of the screen.
da
The piece you are talking about is the bracket that holds the lcd and glass together and holds the screen in place in the phone.
When you replace the screen these are already pre built on the screen. You could choose to replace it but that requires lots of heat and a very steady hand.
Best thing to do is to replace the screen.
Punteggio 1
2 Commenti:
Is this "bracket" plastic, rubber, or a composite? I'm curious. This could affect how I heat it. Am trying to be careful.
Thanks a lot :)
da
It's a rubber meant to absorb energy from impacts to protect the screen.
da
Aggiungi la tua risposta
Joseph Prekins sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 4
Tutti i Tempi: 453
