Salta al contenuto principale
The Lenovo Yoga 2 13" can convert from laptop to tablet, tent, or stand mode with hinges on the side. It was released in January 2014.
Why is laptop getting automatic shut down?
Whenever i'm turning on my laptop then preparing automatic repair option is coming and then the laptop is getting shut down. I thought that windows may have crashed but I'm also unable to open the boot menu option because before that the screen goes off and laptop shuts down.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta più utile
This is a very common problem i deal with all the time at my shop. The bootloop usually comes from two different issues. First issue is windows corruption. For example if a windows update got cut off or the computer got shut down multiple times incorrectly. The second usual issue is a bad hard drive. Now lenovo recovery is done actually with a button on the side of your computer depending on the model. If you take a paper clip and look on the left and right side of your laptop there should be a tiny hole. Sometimes the whole has an arrow next to it. IF you turn the pc off then insert a paperclip into that hole it will turn on and give you options for boot and recovery. Second option you have is making a windows bootable iso. There are plenty of videos on how to do that. You just need a 32GB flash drive and you can boot into that and reload windows. If that dosent work then you most likely have a bad hard drive.
Punteggio 1
1 Commento:
The solution is the one commented by Das Repair.
Additional information: You can use a 16GB USB to install windows 10.
da
Aggiungi la tua risposta
suvankitprusti2000 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 10
Ultimi 30 giorni: 30
Tutti i Tempi: 2,582
